No Fuel Pressure & no Spark, no start
Old Feb 17, 2011 | 09:13 PM
rmucha's Avatar
rmucha
Exclamation No Fuel Pressure & no Spark, no start
Ok long time reader of the site you guys have helped me alot w/ my truck but this is my first plee for help.
I have an '02 1500 4.7L 2wd w/ 96k, it cranks strong but will not start. When I was not hearing the fuel pump kick on (like normal) when turning the key to on I checked my fuel pressure and had no fuel pressure (DUH) I thought the fuel pump was the problem. Not so, replaced fuel pump still the same checked for spark by grounding the plug to the block and turning it over and the same using a spark tester I normally use on my lawn mowers and both showed nothing. I also replaced the ignition switch in the column ($25 was cheap and a hope for a fix). Reason for the switch swap was my gauges no longer regester anything w/ key in on position, so thinking it fried. Tried checking for voltage off the plug for the coils but not sure what I should be getting (volts), but also even if the coils were not getting power wouldn't I still have the fuel pump kick on? Last piece to add is that I had a Viper remote start/alarm that was installed the week I bought the truck in Nov '01 it had a fried and melted 30 amp fuse coming off a pink wire w/ wht strip from the ignition switch (so I removed the alarm and remote start, no change). Oh and I did check all the fuses and relays, all good. Please Help
Old Feb 17, 2011 | 09:28 PM
slimvela's Avatar
slimvela
wow, from what you have written I think you have a multitude of signals missing...where to begin...??? hmm, this is one I would have to have in my garage hooked up to my scan tools/laptop.
I would almost go straight to the ipm/pcm simply to look for signals...fuel pump, gauges, 'spark', timing signals...where did they all go
Old Feb 18, 2011 | 12:43 AM
freestyledude's Avatar
freestyledude
Try the key dance and see if it'll pull codes
Old Feb 18, 2011 | 07:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Does the 02 4.7 have ASD (Auto Shut Down) relays like the 5.7? If so they stop the fuel pump from priming and also stop the coils from firing.
Old Feb 20, 2011 | 09:30 PM
rmucha's Avatar
rmucha
Found the problem. The 12 volt input to the PCM had corrosion and rotted off. So I had no power to the PCM. I was able to cut a hole in the back of the PCM and solder a wire to the pin and crimp to the wire in the harness. Bit of Mickey Mouse engineering but the truck runs. Then I resealed the hole in the back with liquid electrical tape to keep it dry. See how long it lasts. Thank you for the input. And yes the 4.7 does have and ASD relay.
Old Feb 21, 2011 | 08:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Wow.....good job locating and resolving the issue.
