no rear brakes
Old Feb 19, 2011 | 07:33 PM
rollingdodge's Avatar
rollingdodge
Default no rear brakes
hello i just noticed that i dont have any rear brakes, what would cause this? the pads have good life an rotors look good to not much wear. are both the calipers locked up?
Old Feb 19, 2011 | 10:29 PM
MikeHTally's Avatar
MikeHTally
If the calipers were locked, you'd likely have more rear brakes than you could stand. How do you know you have no rear brakes?
Old Feb 20, 2011 | 11:53 AM
rollingdodge
cuz i have a very steep driveway and when it was ice, i went down it and my front will lock up and my backs wont. not even a lil bit. and you can tell that i dont have the stopping power i used too.
Old Feb 20, 2011 | 06:59 PM
socket462's Avatar
socket462
Are you sure you don't have RWAL (Rear wheel anti-lock) brakes?
Old Feb 20, 2011 | 07:55 PM
hyperjay's Avatar
hyperjay
I suggest getting the rear axle on a set of jack stands, and actually confirming that you don't have rear brakes. The rear end isn't going to lock up if you have rear anti lock brakes.
Old Feb 21, 2011 | 09:01 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, not all trucks have 4 wheel anti-locking brakes.
Old Feb 22, 2011 | 06:36 AM
socket462's Avatar
socket462
That is what is supposed to happen when rear wheel antilock brakes are functioning-- the rears will NOT lock up.
Old Feb 26, 2011 | 11:44 AM
rollingdodge
but the abs wont be on and they still wont lock up? and on glare ice they should, no problem with no weight back there.
Old Feb 26, 2011 | 03:11 PM
MikeHTally's Avatar
MikeHTally
ABS isn't on or off. And I believe all trucks have at least rear ABS.
Old Feb 26, 2011 | 08:24 PM
Speedaholic's Avatar
Speedaholic
