Whats the appropriate name of this rubber pipe?
Old Feb 20, 2011 | 05:37 PM
vivini's Avatar
vivini
Default Whats the appropriate name of this rubber pipe?
I can fix it i just dont know the actual name of this pipe... it runs into the fire wall. And it's shooting anti freez out, and because of that i am over heating
Thanks
Old Feb 20, 2011 | 06:34 PM
T-Muns's Avatar
T-Muns
Heater hose...should be a quick and cheap fix. Make sure to top up your coolant.
Old Feb 20, 2011 | 11:25 PM
brettj2408's Avatar
brettj2408
correct that is a heater hose
Old Feb 21, 2011 | 08:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Might be a good time to replace both of them and check the rad hoses also too
Old Feb 22, 2011 | 08:19 AM
vivini's Avatar
vivini
Thanks all fixed 30 mins of work....now next problem after fixing i put truck in 4x4 to get out of my lot.....i tried to shift it back into fwd and you can tell its disconnected or somthing...you can shift from 2wd all the way to 4wlow with 1 finger.....shifter rod maybe?
