wheel bearing
Old Feb 21, 2011 | 03:53 PM
patrapper's Avatar
patrapper
Default wheel bearing
I have a 2006 1/2 ton Ram four wheel drive
front driver's side wheel bearing is bad
so the garage calls me and says it is a dealer only item, priced at $230
sound right?
Old Feb 21, 2011 | 04:10 PM
RamTracks02's Avatar
RamTracks02
I just checked autozone's website... $175.00 for a Timken hub assembly... Shouldn't be a dealer only part, but i guess that's not a terrible price for an OEM bearing
Old Feb 21, 2011 | 09:44 PM
hdvespa's Avatar
hdvespa
that $230.00 price is about what the dealer in Pittsburgh PA area wanted, I myself went with a Timkin from Autozone this time. My truck has about 95K miles and this is the 2nd wheel bearing ont eh driver side for me. 1st one went at 45K then the passanger went close to 60K mikes. Back then the OEM was closer to 200 even for the bearing itself.
Old Feb 21, 2011 | 11:10 PM
Marx's Avatar
Marx
Canadian OEM price for that is about $400 (with abs), so $230 sounds good lol
it's so expensive because they have to replace the entire wheel hub because the bearing is a non removable/serviceable
Old Feb 22, 2011 | 06:21 AM
patrapper's Avatar
patrapper
thanks guys, I'll look into a Timken, nut he didn't check at Autozone
hdvespa, that price is spot on, GO STEELERS
I'm out by the airport
Old Feb 22, 2011 | 06:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ebay for less that $100 with Timiken + ABS sensor and you put it on yourself.
