engine runs cold??? HELP
Old Feb 27, 2011 | 01:46 PM
That1guy's Avatar
That1guy
Mine is an 02. So my fan never disconnects from the water pump?
Old Feb 27, 2011 | 02:13 PM
MikeHTally's Avatar
MikeHTally
It should. Temperature-controlled cooling fans have been around for a while.
Old Feb 27, 2011 | 03:00 PM
drewactual's Avatar
drewactual
Your 02 has a temperature element in the clutch mechanism. It simply may need to be cleaned is all.
I took mine out and went with an efan rig- I was more impressed with that simple mod than many of the highly touted and expensive mods. The parasitic loss of power just by that heavy fan is nuts... I rec you take this opportunity to go efan- it is FAR superior to mechanical/clutch fan in performance and added tq off the line.
