window problem
Old Feb 27, 2011 | 10:55 PM
BAnders's Avatar
BAnders
Default window problem
has anyone had this problem? i replaced all 4 speakers with new ones, double checked wires, connected window/door harness, put panel back on and 3 passenger windows dont work. driver's side is fine. took off the panels again and check the connections, checked the fuse box and nothing. please help me out here.
p.s. who was the a-hole that designed the rear speaker mounts? 3 screws? now i have to break out the drill to adapt for an aftermarket speaker
Old Feb 27, 2011 | 11:13 PM
MikeHTally's Avatar
MikeHTally
Common problem with the windows. It's the driver's door module. Make sure the connectors are secure. A little contact cleaner on the switches and connectors can't hurt.
Old Feb 28, 2011 | 07:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed, could be just the switch. I am assuming you checked the wiring in the rubber boot from the door to the body? Did you test the window motor itself?
As for the speaker, a little creativity never hurt anyone. I wont bother to tell you my stories.
