Simple Wheel Bearing Question
Old Mar 4, 2011 | 09:21 AM
jasonb135's Avatar
jasonb135
Default Simple Wheel Bearing Question
At work right now and I dont have access to the manuals. 2006 1500 2WD Quad Cab 5.7 - What are the wheel bearing torque specs?
Old Mar 4, 2011 | 09:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can download the 06 Srvc Man from the links in my sig but I did mine snug and then the standard 90* turn
Old Mar 4, 2011 | 03:33 PM
cg1022's Avatar
cg1022
best bet is snug it up to set it, loosen it up, than re torque to 50 FT LBS. The norm is to snug than loosen 1/4 turn, but every one has a diffrent feel for snug. Play it safe 50 FT LBS
Old Mar 8, 2011 | 09:30 AM
jasonb135's Avatar
jasonb135
Was reading the sevice manual last night and the 3 bolts that hold on the wheel bearing are recommended to be torqued at 120 foot pounds, why do you guys suggest snug and 90 degree turn, or 50 foot pounds?
