Whine under the hood when accelerating
Old Mar 31, 2011 | 03:57 PM
ilducecorvo88's Avatar
ilducecorvo88
spent the morning under the hood...loosened the belt and spun every single pulley by hand. no play, no noise. Checked everything i could think of...clamps, bolts, etc. everything's tight. Started it after putting the belt back on, held the throttle open @ about 1000 rpm, there's the noise. Revved up and back to idle, sound stops when it returns to idle. Maybe I just couldn't spin the pulleys fast enough to make the noise??? Any fresh ideas?
Old Apr 20, 2011 | 05:32 PM
Dodge_Ram_3500's Avatar
Dodge_Ram_3500
Mine just started this yesterday! its fishing season so I've been in alot of wet woods roads, driving thru puddles, and I remember driving thru one that was quite deep (at least up to the hubs), drove the truck home, got in it later to go to town and i started hearing the whine. I'll let ya know if I can figure it out!
Old May 6, 2011 | 08:30 PM
dodgerodbrky's Avatar
dodgerodbrky
Not familiar with all the different models but does your fan have a fan clutch? Just a thought. Sounds like you have tried most everything else. Good luck with it. I hate those kinds of issues as well. Been there done that. Mine just happened to be the lower idler pulley.
Old May 7, 2011 | 07:53 AM
pitbull24's Avatar
pitbull24
Sounds like you still haven't zero'd in on where exactly the "whine" is coming from. Def sucks to start replacing parts you're not sure need to be replaced. Long shot here, but have you checked your tranny fluid? A "whine" could be a pump noise in your tans. Check the fluid and make sure the pump's not being starved, or worse, something clogging up things(debris). Get someone to help with the throttle while your under the truck, so you can stick your head right in there.
Old May 7, 2011 | 01:22 PM
Bent's Avatar
Bent
I'd second the suggestion to get a mechanic's stethoscope, they are cheap - and they are indispenable tools for this kind of thing.
In the meantime, you could use a cut-off broom handle to do the same thing, put the flat end against your ear, and the rounded end against your -
  • alternator housing
  • a/c pump housing
  • power steering pump body
  • idler pulley brackets...
But make sure you don't slip and get it driven into your skull - that would kinda suck.
Old May 7, 2011 | 01:37 PM
hemi mama's Avatar
hemi mama
talk about strange noises...i have 05 1500 hemi 4x4 with a whole lotta kilometers on it....just replaced the 2 idlers but instead of it screaming like a banshee from hell it now sounds like i have a chorus crickets under the hood..the idlers replaced according to invoice bill were 68058372aa shield and 38058 idler pulley. what else can be causing this very annoying and downright embarrassing noise coming from my baby?
Old Sep 2, 2011 | 04:18 AM
angrykiller1's Avatar
angrykiller1
Default NOISE from engine during acceleration
i too have a noise. i am a retired mechanic. i feel the noise is a vacuume leak on the engine. i will know soon. sounds like a blown plenum gasket under the intake manifold. seems all these engines do this.
Old Sep 2, 2011 | 04:19 AM
angrykiller1
my last dodge ram had the plenum gasket i found it in the oil pump when i pulled the pan.
Old Sep 2, 2011 | 06:37 AM
Gone Fishin's Avatar
Gone Fishin
I vote idler pullies, I just had an issue with mine. Only way I found them was to remove and spin loose, unbolted from the mount. All three bearing were getting dry 160K on them.
Old Sep 2, 2011 | 09:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
2nd gens had plenium gaskets issues. 3rd gens.......nope
if you think it is vacuum related then a can of brake or carb cleaner will tell you very quickly
