Right Brake Light doesnt Illuminate
02 Ram 1500, lamp out reading on dash and the right brake light will not illuminate. when the parking brakes are turned on the bulb illuminates, but as soon as brakes are applied the bulb goes out. Any suggestions?
-Already changed out the bulb for a new one.
Are you sure the new bulb was a good bulb? Is the bulb socket on the tail light in good condition with no corrosion or melting? You can try to download with Service Manual and use it to check the wires in the schematics.
Welcome to the site
Welcome to the site
You may need a new circuit board, It's the white piece that the lights plug into. I had to change the left one on my truck. It would light when I hit the key fob, wouldn't light up when I turned the lights on or hit the brakes.
Rayk3, that sounds like a logical answer. It was just confusing to me because, the light came on when the parking lights were on, but soon as brakes were applied the bulb went out. I reckon i can swap the circuit boards around to see if that illiminates the problem..
Any other suggestions are appreciated.
