heat directional problems
Old Mar 31, 2011 | 05:22 PM
ryankep's Avatar
ryankep
Default heat directional problems
I have a 2004 2500 and 2005 1500 ram hemi's.Both have no air going to feet.2004 was having no heat to defrost.Now it is trying to keep up with my 2005.Both now have no air to feet.This both happened within 3 months of each other any help and where a particular part is located would be appreciated.when put on feet comes out defrost
Old Mar 31, 2011 | 08:08 PM
LazyLightning's Avatar
LazyLightning
Sounds like that blend door in the dash unit. Search around on here, you'll find the fix.
Old Mar 31, 2011 | 08:20 PM
big guy's Avatar
big guy
Welcome to frozen feet club. Sounds like a broken defrost door. Check here for tsb info.
http://dodgeram.info/tsb/2003/24-004-03.htm
Use heater treater parts for replacement.
http://www.heatertreater.net/Ram%2002-08%20Listing.html
Good Luck.
edit. couple more links for ya.
http://www.dieseltruckresource.com/d...d-t210483.html
https://dodgeforum.com/forum/3rd-gen...termarket.html
Old Apr 1, 2011 | 02:03 PM
ryankep's Avatar
ryankep
Default thanks
Thanks for the imfo .Much appreciated.great place to get imfo for my rams.Going to give this imfo to my buddy mechanic to give me a price labor.Little more work than I am willing to get wrong.While I am here and new wanted to let known a problem I had on my 2500.2 years ago I would hit a bump in the road or pothole and would get severe tire hop and steering out of control.To the point I thought I was going to lose control of the truck.Not fun when towing a 20 foot bass boat at 70.Turns out low tire pressure in my Michelin Lt 245 70R 17's could NOT believe that would happen with just low tire pressure,the cars around me actually scattered like flies when they saw it Quite scary.WELL THAT WILL LEARN YA.I check my tire pressure once a week.
Old Apr 1, 2011 | 03:58 PM
brad m's Avatar
brad m
I highly recommend dealer parts. There are new clips that have stop built into them. It is a very easy job to pull the dash out and then remove heater box. I would never cut anything open. Do it right or don't do it. I just replaced mine 2 weeks ago. Buddy and I had it done in 4&1/2 hours.
Old Apr 2, 2011 | 06:56 AM
30_30 Win's Avatar
30_30 Win
All previous responces could very well be correct. My problem turned out to be the "fan speed- temp. selector". I found this AFTER tearing my dash apart to get at my blend doors and found them to work fine. $ 125.00 later I had defrost air again.
