PCV Valve on o3 hemi
Old Apr 6, 2011 | 02:07 PM
bigbillhemi03's Avatar
bigbillhemi03
Default PCV Valve on o3 hemi
Whats the PCV valve do and does it need changed on a regular basis? If so when do you change it?
Old Apr 7, 2011 | 09:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
PCV is Positive Crankcase Ventilation and it is a plastic valve that draws air from inside the crankcase to prevent a build up of pressure so your seals do not over pressurize and leak.
How often to change it? Depends on age and mileage but if you have an 03 and havent done it yet then you should swap it out to be safe. When you pull it out it should rattle when you shake it. If not then it is clogged.
Old Apr 7, 2011 | 01:02 PM
MikeHTally's Avatar
MikeHTally
I've cleaned mine three or four times, but I did just recently replace it at 110K. They're kinda pricey, so you might want to try cleaning it. If the check valve moves, it should still be OK.
Old Apr 11, 2011 | 08:27 AM
bigbillhemi03
Where is it located? Does anyone have any pics?
Old Apr 11, 2011 | 11:04 AM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
You can download the '03 Service Manual from weed's sig. PCV starts in section 25-18. On the 5.7L it's located behind your throttle body on top of the intake manifold. Shows removal and installation in section 25-22. I just ordered a new one, still OEM on mine. Cost $19 on rockauto.com
