Dash Lights
Old Apr 6, 2011 | 06:58 PM
Laxipad's Avatar
Laxipad
Default Dash Lights
I have an '06 1500 5.7L, today at about 25 mph my abs light and my E-Brake light came on and stayed on until I shut the engine off and re-started it. Since then it has not happened again...any ideas on what happened or how to keep that from happening again?
Old Apr 6, 2011 | 07:18 PM
JDG103's Avatar
JDG103
thats a sign that your brake control module is bad...and in some rams that can tell you if you have a bad hub as well
Old Apr 6, 2011 | 08:17 PM
Laxipad's Avatar
Laxipad
Thanks. Gonna get it scanned tomorrow to see what codes are popping up. Any other ideas since the two lights haven't come back since I started it again?
Old Apr 7, 2011 | 08:58 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Be sure to come back and post the DTC codes if any are found
Old Apr 7, 2011 | 10:27 PM
Laxipad's Avatar
Laxipad
No codes...and no issues today with the sensors being tripped...maybe moisture?
Old Apr 7, 2011 | 11:11 PM
JDG103's Avatar
JDG103
the brake control module is a cheap n easy fix..cost right around $12
