Abs and Brake light beep
Old Apr 6, 2011 | 10:16 PM
Paddyman89's Avatar
Paddyman89
Default Abs and Brake light beep
I was driving today when the abs light and brake light came on followed by beeping. It went off later in my drive. This has happened to me twice out of the 6 or 7 different drives ive taken today.
Old Apr 7, 2011 | 12:49 AM
freestyledude's Avatar
freestyledude
Replace/check the wiring for the rear wheel speed sensor. It's on top of the rear pumpkin. One bolt, and then carefully pry it out. Don't let anything fall into the open hole
Old Apr 7, 2011 | 01:21 AM
Paddyman89's Avatar
Paddyman89
Ok, I will check it out, From what I found online it says that replacing that is a real easy fix.
Old Apr 7, 2011 | 08:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can always download the service manual for your truck from the links in my sig but in the mean time you also need to see if you have any DTC codes logged in the PCM.
