Recon Big Rig Running lights/ Dash Lights
Old Apr 8, 2011 | 07:38 PM
SA9553's Avatar
SA9553
Default Recon Big Rig Running lights/ Dash Lights
Hi, I have a set of Recon Big Rig Running lights Im looking to install on my 2006 Dodge Ram. They have the white courtesy light option. What Im looking to do wire the courtesy light to the dome light in the cab. My question is what is the easiest way to wire it. Is there a wire under the dash, since that is how Im routing the wires through the truck. Also Im looking to change my lights in the dash( Behind the gauges) and the lights behind the control ***** for the A/C. Looking at some LED bulbs. What I need to know is what type of bulb it is. Like what bulb number??? Thanks for your help.
Old Apr 8, 2011 | 07:44 PM
Deathrend's Avatar
Deathrend
I think it's sent up the right side of the front window, under the the Handle.
Old Apr 8, 2011 | 08:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check in our FAQs at the top of the section for a thread on changing the dash lighting to LEDs.
