CVI Reset?
Old Apr 13, 2011 | 12:14 AM
truckin151's Avatar
truckin151
Default CVI Reset?
With out a scan tool (the one the dealer has) how can I go about reseting the CVI (Clutch Volume Index)? Just picked up a new part to boost my line pressure but it says I need to reset the CVI in order for it to relearn the the new line pressures.
I was thinking that I could just re-install the trans tune on my DSP as that adjusts the line pressure within the tune, so I would imagine that with the new part in place it would reset everything. I'd rather not go through that though if I dont have to cause I dont want to have to let the truck relearn the custom tune for the cam again as it acts "tempermental" right after the tune is installed and needs about a hundred miles or so of driving to really get it to learn it. So if there is a fuse pull or key fob that would do the same thing I'd want to try that route first, Just not sure that there is such a thing.
Old Apr 13, 2011 | 10:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
OlDirtyJohn might know but my understanding was only the proprietary StarScan tool could do it
Old Apr 13, 2011 | 02:01 PM
truckin151's Avatar
truckin151
Would you think that doing the reset via reloading the Htc file would reset it? The tuner does rais the cvi in the tune file over stock,
Old Apr 13, 2011 | 02:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Honestly, its beyond me bro.
