03' 1500 Where to run power wire?
Old Jul 1, 2005 | 01:58 PM
MeanGreenRam's Avatar
MeanGreenRam
Default 03' 1500 Where to run power wire?
Where do you guys run your power wires? I don't see any easy way to run my 4gauge power wire. I need to get through the firewall somewhere so if anyone has suggestions I'd appreciate it!
Old Jul 1, 2005 | 02:04 PM
osteodoc08's Avatar
osteodoc08
Default RE: 03' 1500 Where to run power wire?
A 4 gauge wire is pretty thick wire to run through the rubber grommet that is already there. Perhaps Blackacid can chime in cause I know he's gotta be runnin some serious wires to his amps and speakers.
Old Jul 1, 2005 | 05:02 PM
alienyzf's Avatar
alienyzf
Between the battery and engine on the firewall you will see where a bundle of wire is encased in a rubber gromet. Pull out and cut a slit for your wire and run into cab.
Old Jul 3, 2005 | 02:21 AM
Randall's Avatar
Randall
I ran mine on top of the frame on the drivers side. I ran 1/0 gauge and have it wrapped in flex loom. I drilled a hole under the rear seats and installed a grommet and ran the wire through there. I wanted to keep the cable away from my speaker and RCA cables to avoid any interference.
