Error code p1128
Old Apr 17, 2011 | 12:09 PM
nate73's Avatar
nate73
Default Error code p1128
I am getting an engine code p1128 it did not come on until i put in new o2 senors i also put in a new map sensor, does anyone know what i can do to fix this, could one of the o2 senors be bad.
i have a 2006 ram 4wheel drive 2500 with 5.7
thanks
Old Apr 17, 2011 | 12:23 PM
HammerZ71's Avatar
HammerZ71
I would think it would have more to do with the MAP sensor than the O2s. Bad or you ain't got it plugged in good. I've seen new ones not work because of being handled and having oils/etc. from fingers on it...
Old Apr 21, 2011 | 07:59 AM
nate73's Avatar
nate73
checked the conection on the map sensor, looked good, now im getting the codes p0305, p0132 and still getting p1128, everything is pointing to a bad o2 sensor or the wiring for it what do you guys think
Old Apr 21, 2011 | 08:03 AM
HammerZ71's Avatar
HammerZ71
Those are engine misfire codes, don't really see how a bad o2 is going to cause the engine to misfire, but if it started right after you put the sensor in, yank it and replace it. Would rule it out, anyway...
Old Apr 23, 2011 | 11:27 PM
nate73's Avatar
nate73
would anyone have a clue on which sensor i should replace , left side or right side, before cat or after cat
Old Apr 24, 2011 | 01:28 AM
Owensue's Avatar
Owensue
If you still have your old sensors, swap them one at a time to see if there is any change. Were you having any codes before the swap?
Old Apr 29, 2011 | 06:54 PM
nate73's Avatar
nate73
My cousin works at a dodge garage ,he said about changing out the left precat o2 sensor, so ill try that and go from there
Old Jul 22, 2013 | 09:19 PM
Dennis1960's Avatar
Dennis1960
I got a P1128 code error. Ask mechanic what it could be but gave me a long list of possible problems so I was not amused by their diagnosis. So I attached an Autel 519 Scanner and said oxygen sensor temperature heater error on bank 1. There are 2 sensors that I could find....Bank 1 upstream and bank 1 down stream.....
I took a chance and replaced the upstream oxygen sensor. Problem solved....
