LIft Help!
Old Apr 18, 2011 | 07:20 PM
RedRobin's Avatar
RedRobin
Default LIft Help!
I have an 07 1500 4x4 and i have a leveling kit on there with 35's now. i am wanting to put on a 3 inch body lift and then crank the torsion bars about 2 inches and put 2 inch blocks in the rear? will this lift work and look good? well it be pretty high?? if you know anyone with this set up please post pics! THANKS!!
Old Apr 18, 2011 | 08:34 PM
nussdawg395's Avatar
nussdawg395
Won't work bro...you don't have t-bars you got coil overs.
Old Apr 18, 2011 | 08:53 PM
HammerZ71's Avatar
HammerZ71
Sounds to me like you need to slide under your truck and learn some things. As stated, you have coil overs, besides even if you did have a torsion front, level kit + key crank = broken CV axles.
Although I think a level + body lift combo looks real good and 5" up front is an excellent lift height with 35" tires. I wouldn't go any bigger than the 35s unless you want to start replacing ball joints, tie rods, the rack & pinion and of course, those CV axles...
Old Apr 18, 2011 | 09:59 PM
Matt99's Avatar
Matt99
I also think 5" is the right amount of lift for 35s.
Like they said, you need to take a look under your truck
