Repeat Question
Hate to ask again , but none of the search features worked in finding my old thread.
I need to change the gear lube in both differentials, but do not know the capacity or if there is a gasket involved. 2006 Mega cab 1500 4x4 with a 3.73 axle.
Thanks, this time I will write it down.
You will need 3 qrts of synthetic and a Permatex to "make" a gasket.
Buy 75-90 if you do not tow or 75-140 if you do tow. If you have as LSD you will need the friction modifier to add to the oil. Put it in first and then the oil
Our FAQs have most of this info already covered for you though
Differential Fluid Change Tutorial
