A/C question
Old Apr 25, 2011 | 09:52 PM
ah21283's Avatar
ah21283
Default A/C question
my A/C works fine but the switch closest to the passenger side, the one that changes where it blows from, doesnt work? its stuck on the top vents, i cant put it on feet or defrost
Old Apr 25, 2011 | 11:37 PM
Brandon Anderson's Avatar
Brandon Anderson
Put your head down by the unit and switch the ****. If you can hear the blend door(s) trying to move, then your doors are bad. If not, the switch is bad. Given Dodge/Jeep's track record with this issue, I can pretty much guarantee you that it's the blend door(s) though.
Old Apr 26, 2011 | 11:19 AM
ah21283's Avatar
ah21283
easy fix?? how much am i lookin at to replace the blend doors?
Old Apr 26, 2011 | 07:01 PM
Thelast929's Avatar
Thelast929
Just did my blend doors. Not as hard as I thought. There are multiple posts on this forum that are helpful. I hope to be posting my own "helper" post soon. Because someone else on here helped me out, I'm willing to help out with any tips and info that I can as well. Just drop me a line. And yes, I went with the aftermarket doors as opposed to the poorly designed factory ones.
