Auto transmission fluid ?
Old Apr 27, 2011 | 01:39 AM
Brandonc24's Avatar
Brandonc24
Default Auto transmission fluid ?
What is the capacity on a 06 Ram 5.7 Hemi. I checked I my owners Manuel and it doesn't give the ATF capacity and I have looked online and found a wide range of answers.
Old Apr 27, 2011 | 07:29 AM
MikeHTally's Avatar
MikeHTally
Depends on what you're doing. If it's just a drop 'n' drain and filter replacement, usually around 7-8 quarts. A full flush (not recommended) takes about 17 quarts.
Old Apr 27, 2011 | 08:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You should download the 06 Service Manual and look through it not only for this but tons of other educational information you will likely find the need for later on down the road.
P.S. - Check out page 28
AUTOMATIC TRANSMISSION
Service Fill - 45RFE/545RFE 4X2 - 5.2 L (11.0 pts.) 4X4 - 6.2 L (13.0 pts.)
Overhaul - 45RFE/545RFE 14-16 L (29-33 pts.) L
Old Apr 27, 2011 | 09:38 AM
Brandonc24's Avatar
Brandonc24
Thanks guys, I am going to download that service manual right now, thanks again.
