question on engine trouble 2003 4.7ltr.
Old May 9, 2011 | 10:05 AM
davehatts's Avatar
davehatts
Default question on engine trouble 2003 4.7ltr.
1. replaced head gaskets,worked fine
test drove on highway when you went into passing gear would not
go over 100 km engine light starts flashing
found push rod had fell out. put push rod back and still had the
same problem.
checked timing and found one tooth out of time.reset timing
and test drove. truck stopped and would not start. checked timimng
again and was right on,
took off drivers side valve cover and found 3 push rods had fell out
also have replaced crank and cam sensors
Any ideas of what could cause this problem!
Any solutions!
Old May 9, 2011 | 11:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You obviously have some excessive worn valve train parts if your push rods keep falling out from under the rockers
