04 Ram WONT START
Old May 10, 2011 | 11:22 PM
TylerRam1500's Avatar
TylerRam1500
Default 04 Ram WONT START
Kind of new to the site and was wondering if i could get some help here, i have an 04 ram 1500 hemi slt, i am rebuliding it and recently tried starting it and wont turn over. i had to replace ingnition which i had the truck running after that was replaced, and also the cluster. Now when i try to start it all the gauges light up, fuel pump kicks in untill i turn the key and NOTHING! all gauges drop. thought it was my battery untill i noticed the small red light flashing on the cluster so im guessing something to do with safety and the computer??? Any ideas
Old May 11, 2011 | 12:34 AM
HouseApe's Avatar
HouseApe
The security will let it start and then die.
Check for a bad connection at the starter. I've seen the toothed washer on the battery connection at the starter get full of corrosion and caused a massive voltage drop at the starter.
Old May 12, 2011 | 11:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Make sure fuse #23 is good as well as all others. Check and double check all connections and grounds. Make sure the starter is wired correctly. I have wires the solenoid backwards before and had the same issue as you are.
Old May 12, 2011 | 06:56 PM
Gone Fishin's Avatar
Gone Fishin
That sounds like the security light that flashing, when I arm my factory installed system, that light flashes
