"C-Code"...
Old May 24, 2011 | 04:32 PM
dylansav's Avatar
dylansav
Default "C-Code"...
Hey,
So I figured out how to do the check for the "C-codes" today and two of them came up. I have...
05 -MIL indicator output circuit shorted
68 -Driver door unlock output circuit shorted to
ground or voltage
The 68 code makes sense...my driver's door has only been able to be opened from the inside. I can't use a key or the clicker, only manually.
Does anyone know any way to repair these issues? I have no idea where to start.
Thank you for help!
Old May 25, 2011 | 07:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You may just have a bad latch assembly in the door which is why you cannot use the keyfob to electrically open the door but can manually do it. Either that or a pinched wire in the rubber boot from the door to the body.
Both are common issues.
