Last edit by: IB Advertising
Browse all: Brakes
- Dodge Ram 2nd, 3rd, 4th Gen Why is Brake Pedla Soft
Step by step instructions for the do-it-yourself repairs.
Browse all: Brakes
Soft Brake Pedal - Need Advise
I have just finished replacing the rear brakes on my '02 Ram 1500 4x4 and I'm having a hard time getting the brake pedal to firm up. In replacing the brakes, I installed new parking brake shoes & spring kit, new rotors, new calipers & pads. I then had a buddy help bleed the brakes, starting with the passenger rear first.
At first, the pedal would go to the floor, then firm up after a pump or 2. We took the wheels off, re-adjusted the parking brake shoes a little, then bled the brakes about 3 times each wheel, including the fronts (even though I did not replace anything on the front yet). The truck stops, but the pedal still feels soft and the pedal travel seems too close to the floor.
Anyone have any ideas on what I may have missed or done improperly?
Hands down the best and cheapest brake bleeder
Autozone part number 25036
Put the hose on the bottle and push one of the nipples in the hose. Then push the nipple into the bleeder screw and crack open the screw. Then pump the brakes and watch the fluid come out through the clear hose and collect in the bottle.
http://www.autozone.com/autozone/acc...ier=46839_0_0_
Not sure what a cleat tube is. I used a clear pvc tube I had from a brake bleeding kit. The kit was the one like this from Autozone that I've had for a while:
http://www.autozone.com/autozone/acc...fier=70116_0_0_
The tube was a little larger diameter than probably needed to cover the bleeder screw...maybe that made it more difficult to see if air bubbles were still coming out. I think I'll give it another try or two with that siphon bleeder I have, or with the cheat one you suggest from autozone. I'll let you know if that works.
