hemi noisy idiling
Old Jun 15, 2011 | 08:00 AM
chasin tails's Avatar
chasin tails
Default hemi noisy idiling
Newbie to dodge hemi family, I have a 03 ram 2500 with 70K. At idle it noisy like a bearing or water pump sound, but goes away if you increase rpm's. The noise is coming from the left of the alternator and towards bottom of motor. Just purchased and ran fine the ride home of about 120 miles. The gauges are reading correctly. Are the hemi's noisy at idle.
Old Jun 15, 2011 | 09:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. I suggest you take and use a mechanics stethoscope to locate the noise. Also check the exhaust manifold bolts for any that could be broken or loose
Old Jun 16, 2011 | 07:36 AM
chasin tails
Default noisy hemi
Last night I picked up a serpentine belt $40 to change and inspect pulleys. I found a lower idler pulley all busted up. I changed both idler pulley $40 auto zone and everything running smoothly.
Old Jun 16, 2011 | 08:53 AM
abarmby's Avatar
abarmby
Good catch.....I've seen snapped serpentines damage a lot of under bonnet stuff!
Al.
