hemi problem
Old Jul 1, 2011 | 12:03 AM
T-Muns's Avatar
T-Muns
Originally Posted by mjennings86
What if I went for a 2003-04 5.7l would i have the same wiring problems? If I wont does anyone want to buy a 2006 hemi??
2003 would be a lot easier than a 2004+. It has the same C130 dash plug that your current 2002 has. You'll just have to run some new wires and splice some of the others. If you use a 2004+, you're going to have to start from scratch and match everything up. Some other guys have done it so it's certainly not impossible, but it's a project.
On the other hand, the 2003 uses a standalone transmission controller, which means performance tuning with the transmission is limited if you want to set shift points and/or do a big cam upgrade.
Dose anyone know where I can get an 2005 wiring harness? I'm not having any luck.
A guy on DT is selling the pcm and harness that Weed was going to put in his truck...pretty cheap too http://tinyurl.com/44lqprm
Old Jul 1, 2011 | 02:38 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I was also going to suggest that 05 PCM and harness setup on DT. I should buy it back from him.....LOL
