2003 Dodge Ram 2500 Quad Cab
Old Jul 4, 2011 | 02:27 PM
ldbb28's Avatar
ldbb28
Default 2003 Dodge Ram 2500 Quad Cab
Need help! I have a 2003 Ram 2500 quad cab truck 2X4...no power windows or locks or frills. It is a 5speed. My problem is that the digital odometer will not go off. It will go off if I pull the #20 fuse (which is the main power fuse...no other fuses will affect the light) If I turn on the headlights the odometer lights will go off. I did key trick to get codes and these were listed "P2175" & "P2106".....any suggestion &/or help will be greatly appreciated!!!!
Old Jul 4, 2011 | 07:41 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old Jul 4, 2011 | 08:43 PM
dirtydog's Avatar
dirtydog
Moderate User
I would check on the underside of your fuse box that is located in the engine compartment. Alot of guys are having problems with corrosion on the undersides of those panels and it causes oddball electrical gremilins to appear. I'd peek at the underside first and rule out that possibility. it's actually not that difficult of a part to replace if that is the problem. Sounds worse than it really is.
Old Jul 4, 2011 | 10:22 PM
ldbb28's Avatar
ldbb28
Thanks! I'll try that and let you know what I find!
Old Jul 5, 2011 | 12:59 PM
Wy Roadblock's Avatar
Wy Roadblock
Would that be the reason for cruise control working... " on occasion " ??? And power windows only working from drivers controls " on occasion " ??? Darn Gremlins :-P
