Code P0037
Old Jul 12, 2011 | 08:29 AM
philll74's Avatar
philll74
Default Code P0037
2002 1500 reg cab 4x4. Got this code yesterday after the CEL light came on and I did the key dance. Says it is the O2 Sensor 1/2 Heater Circuit Low. So what exactly does that mean? And which O2 sensor do I need to chang? From what I have read there are multiple ones. Thanks, Paul
Old Jul 12, 2011 | 08:43 AM
HammerZ71's Avatar
HammerZ71
This is a simple fix, the code is telling you that the driver's side, post cat O2 sensor is NOT giving a signal to the PCM after the vehicle has reached operating temperature and switches to closed loop.
Replace the sensor...
Old Jul 12, 2011 | 01:05 PM
philll74's Avatar
philll74
So i just need to replace it?
Old Jul 12, 2011 | 03:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
$25 at Autozone or the dealer of your choice. Reset the PCM after swapping it out
Old Jul 13, 2011 | 08:28 PM
philll74's Avatar
philll74
how do you rest the PCM?
Old Jul 13, 2011 | 08:57 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Disconnect the battery posts for 30+ seconds
