Tire Fitment for Lift?? Help!
Old Jul 31, 2011 | 11:33 PM
Ranneyn's Avatar
Ranneyn
Default Tire Fitment for Lift?? Help!
Okay, so i have a 2003 dodge ram. Its a 2wd, sad I KNOW! It has a 3 inch suspension lift from rough country with 33" Nitto Terra grapplers. Looks WAY better then stock. Totally different and looks like a beast 4x4. Im looking to go a little bigger with 35's. So would a 3 inch body lift clear 35's? Im not big on body lifts but i need a little something to clear 35's and i already have the suspension lift. How much of a body lift would i need etc. Thanks for the help.
-Nick
Old Aug 1, 2011 | 12:34 AM
Brandon Anderson's Avatar
Brandon Anderson
33" is stock size for the 20" wheels. With a 3" suspension lift, you should easily clear 35x12.5 tires. Might need wheel spacers or new wheels though to keep from rubbing on your suspension.
Old Aug 1, 2011 | 08:24 AM
dirtydog's Avatar
dirtydog
Moderate User
Look HERE Hopefully it might help.
Old Aug 1, 2011 | 05:30 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
-Nick
Whats sad about it? Ive got an 04 2wd with 12" of lift.
DirtyDog gives a great link to read and Brandon answered correctly. A 3" BL plus your current susp will do you fine. However, offset and back spacing of your rims will determine if you need spacers or not.
