Death wobble brace?
Old Aug 2, 2011 | 10:10 AM
OzzyDodge's Avatar
OzzyDodge
Default Death wobble brace?
When i read up on it months ago I finally found a website that sold what looked like a frame brace to cure the wobble (Mine has it bad with bigger tires). Anyone know where i can by the hardware mentioned below (I replaced plenty of other components already so i assume this is the "real" fix)?
2500 Wobble..AKA "Death Wobble". This is caused by a design flaw in the steering components of the Ram. The factory steering has slack in it which causes the frame to begin to flex out of control. The only way to stop the flexing is to slow down to a crawl. There is a fix that you can do which is aftermarket. The dealer cannot do anything to fix this problem as there isn't an OEM component that stabilizes the steering enough to eliminate this, so don't even waste your time at the dealership. Do a search on Steering stabilizer for 2500's and you will find what you need.
Old Aug 2, 2011 | 11:47 AM
HammerZ71's Avatar
HammerZ71
The search feature can be your bestest buddy:
https://dodgeforum.com/forum/3rd-gen...bble-cure.html
Old Aug 2, 2011 | 01:01 PM
OzzyDodge's Avatar
OzzyDodge
Thanks, I sifted through all the usual threads and somehow missed it.
