Wheel Bearing
Old Aug 2, 2011 | 11:16 PM
jorgysram's Avatar
jorgysram
Default Wheel Bearing
SO i do believe my wheel bearing took a complete **** today, coming home from my cousins house started a funny vibration that then turned to smoking and screetching noise, but has anybody had any luck with chrysler on the recall for the wheel bearing issue? i bought the truck in 08 so i dont even know if they were repaied on it or not, but the driverside hub went out back in december now this one went
Old Aug 3, 2011 | 08:16 PM
Owensue's Avatar
Owensue
that would be a wheel hub and a cv boot, providing that tear is recent, you may need a 1/2 shaft if that boots been torn for a while.
Old Aug 4, 2011 | 01:12 PM
jorgysram's Avatar
jorgysram
ive got my work cut out for me the hub took out the caliper, and the rotor, the joint in the cv is done, so ive got new rotors new hubs, a new caliper and a new half shaft on the way, also havea new thermostat and water pump on the ay cus thethermostat is sticking and the water pump is leaking, found out that my truck was made 3 months before the trucks with the bad hubs tho so im not getting it done on the recall, price for all my wonderfull parts are about 760, that counts 2 rotors, 2 hubs, 1 half shaft, 1 caliper and bracket, and a water pump and thermostat
Old Aug 4, 2011 | 07:10 PM
Owensue's Avatar
Owensue
Mine took out the rotor and caliper too, I had new rotors and pads but wound up buying 4 new calipers ( one was seized ) my parts added up to over 2 grand. The guy changing my hub split my cv boot, and the 20$ part hasn't been changed yet so I'll need a half shaft too. I wish sometimes I had more time to do my own service.
Old Aug 4, 2011 | 07:39 PM
contractors Hemi's Avatar
contractors Hemi
Ya I am changing my second one in a month, the build date on my 2006 is September too. So no luck there, the second one is failing much faster than the first one did.
Old Aug 4, 2011 | 08:02 PM
jorgysram's Avatar
jorgysram
i got the skf hubs for my truck since the timkens were out of stock, 160 a piece on rock auto, but i was wondering if anyone has run them? if they have how well have they held up for you
Old Aug 5, 2011 | 01:13 PM
contractors Hemi
I bought timkens from a seller on amazon for 130 and 160 shipped to my friends US address. Hope it works out for you, it's no fun spending money that doesn't make it better!
