code p0700, p0876
Old Aug 6, 2011 | 06:52 AM
scwpd's Avatar
scwpd
Default code p0700, p0876
went to leave work this morning and when i hit the break the truck kinda sputtered for a second and then the cel came on. hooked up the sc and pulled these codes
wanted to make sure i got these right
p0700 = general trans code
p0876 = underdrive pressure switch
and from what i have been able to gather the solenoid pack is gone and needs to be replace
can someone tell me if this is right
Old Aug 6, 2011 | 10:48 AM
dirtydog's Avatar
dirtydog
Moderate User
That would be the cheapest and easiest place to start other than making sure you have the correct amount of fluid in there?
If it's not the sensors then your trans control module could be bad.
Old Aug 7, 2011 | 02:56 AM
scwpd's Avatar
scwpd
i checked it again before i came to work and it was 1/2 quart low so i topped it off and it drove just fine to work no cel or anything could it have been just a hick up or is something about to go out
Old Aug 7, 2011 | 09:33 AM
dirtydog's Avatar
dirtydog
Moderate User
Did you check while it was hot or cold? Suppose to be at operating temp...The trans, not the engine. You can't really just start your truck and let it get up to temp. It must be driven a little to warm the transmission up so you can properly check the fluid.
Old Aug 7, 2011 | 10:27 PM
scwpd's Avatar
scwpd
drove it around for about 10 or 15 minutes and checked it
Old Aug 8, 2011 | 08:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When was the last time you did preventive maintenance and changed all the fluid and filters?
Old Aug 8, 2011 | 11:58 AM
scwpd's Avatar
scwpd
I think that's part of the problem had it flushed a few months ago and had a problem with the converter draining ended up changing the return line from the cooler and seemed to fix it and yes they checked the filters after reading a post from here I showed them
Old Aug 25, 2011 | 10:04 PM
r1perk's Avatar
r1perk
Default Me Too!
I have changed the pressure sensor 3 times, 2 solenoid packs, and a valve body. And yes new filters, correctly installed.
Still no help. As soon as the trans gets up to operating temp it goes into limp mode. Always sets P0700 & P0876.
Anyone have any ideas? I have a 12 Ga., just can't decide what part to shoot first.
Old Aug 25, 2011 | 10:56 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
when you get a p0700 you are normally looking at a replacement or rebuild
Old Aug 27, 2011 | 09:03 PM
scwpd's Avatar
scwpd
After topping of the fluid I have not had any more problems don't know if ot was just and electrical glitch cause for a couple of days before this as soon as I would turn my radio on it would shut off and when I turned it on it would be completely reset (time, setting)
