Something A little wierd with transmission
Old Aug 8, 2011 | 11:49 AM
Gorhad's Avatar
Gorhad
Default Something A little wierd with transmission
2004 Ram 1500 2wd QC 121000 miles
Sometimes its a little hesitant on engaging gear, when you pull off only.
For example when you are parked or stopped at the lights and go to pull off it takes a few seconds to engage and makes a slight clunk noise. It doesnt happen all the time its quite random.
Fluid level seems to be ok, shifting is very smooth.
I pull my 2500lbs lawn trailer/equipment every day just wondering if its having a toll on the tranny. The heat in FL is around 92 deg
Thanks
Old Aug 8, 2011 | 01:16 PM
MikeHTally's Avatar
MikeHTally
Well, you should be on your fifth tranny fluid/filter change (at least). That severe duty is taking a toll. How many miles on the current change?
Old Aug 9, 2011 | 04:44 AM
Gorhad's Avatar
Gorhad
I have only had the truck about 2 months, bought it used, so i dont know the history with regard to the fluid and filter changes.
Thanks
Old Aug 9, 2011 | 08:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Whenever you buy something used you assume NO maintenance has been done and you change everything. Thats plugs, wires, air/oil filters, engine/trans/rear oils, check brakes/belts/hoses, check front and rear engine/trans seals and pans for leaks, check ball joint boots, coolant condition, ECT
