Gas Cap & Error Codes.
Old Aug 15, 2011 | 03:01 PM
okse's Avatar
okse
Default Gas Cap & Error Codes.
I"m pulling up codes that indicate a EVAP leak in my system. I've replaced the gas cap with a locking gas cap, but the lock is broken. I'm looking for purchasing a good quality gas cap. Can someone please link me to a good quality gas cap?
I've since replaced all clamps with metal screw type clamps before I go out and spend $200 for a new canister & solenoid.
Codes: 441, 440
Old Aug 15, 2011 | 04:38 PM
MikeHTally's Avatar
MikeHTally
The lock has no bearing on the seal. Have you replaced any of the hoses on the evap system? I've read a few instances of one of the short hoses down there having a split, causing a vacuum issue. Mine throws a code once in a blue moon, but it goes away after a day or so and I never remember to look when I'm under it to see if one of those hoses has a hole or a split.
Old Aug 15, 2011 | 04:54 PM
okse's Avatar
okse
The cables seemed to be OK with no cracks but this last time I checked one of the original plastic clamps was off and dangling there. I replaced all those plastic clamps with a metal clamps. I did not notice any clogs in the following, Evap canister, the Evap canister round, purge solenoid or the other round part connected to the purge solenoid.
I reset the code and hoping that this will fix the issue. Time will tell if the code comes back on.
Old Aug 16, 2011 | 12:07 AM
mbaseball3's Avatar
mbaseball3
I too chased the Evap leak bs. I bypassed the gas cap and hoses idea. Under visual inspection all mine looked brand new. I read somewhere about replacing the white valve plug on the charcoal canister under truck. $13 bucks at dealer fixed gas cap light. If all else fails, try that.
Old Aug 16, 2011 | 09:20 AM
okse's Avatar
okse
White Valve plug? Do you remember the name of this? I because I don't see anything white on either the round charcoal canister or the square charcoal canister. I have a 2003 RAM 1500 5.7 Hemi
Old Aug 16, 2011 | 08:16 PM
mbaseball3's Avatar
mbaseball3
Mopar part # 04891685AB. Evap purge selonoid or something like that.
