Ball joints helpppp!!
Old Aug 22, 2011 | 08:42 PM
Killasrt4's Avatar
Killasrt4
what the lug nut size on my wheels.. 03 hemi stock wheels
Old Aug 23, 2011 | 12:28 PM
dodgeboy1979's Avatar
dodgeboy1979
the tire pressure will be on the sidewall of the tire. i think the lugs are 7/8
Old Aug 23, 2011 | 03:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
swap and rotate wheel from front to back. this will eliminate rims and tires. from there check the front end susp and i would start with tie rods
Old Aug 23, 2011 | 07:28 PM
Killasrt4's Avatar
Killasrt4
yea tie rods were fine and ball joints seemed fine..but i didnt get a bar under the tire,i just tried yanking them by hand..it must be the alignment and tires the tires r worn really bad all around..the front tires r badly worn in the out side edges
Old Aug 23, 2011 | 07:29 PM
Killasrt4's Avatar
Killasrt4
r the lugs for sure 7/8?
Old Aug 27, 2011 | 03:44 PM
Killasrt4's Avatar
Killasrt4
Old Aug 27, 2011 | 04:14 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
i use a 190mm but the tool that came with with the truck will fit too
Old Aug 27, 2011 | 04:29 PM
Killasrt4's Avatar
Killasrt4
i have no jack to lug wrence nothing came with the truck
Old Aug 27, 2011 | 05:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
That's cool. They're junk anyway. Either use a 19mm socket on a 1/2" breaker bar or torque wrench or get a 4 way lug wrench.
Old Aug 27, 2011 | 06:01 PM
Killasrt4's Avatar
Killasrt4
ok..yea i picked up a 7/8 impact socket for the lug nuts..i tried a 22m on them and it was close and a 7/8 is a tiny bit bigger so hopefully it will fit them correctly..
back to the ball joint..could they really be bad at 81k?..cause it didnt do this bad wobble at low speeds when i got it 4 weeks ago..
