Need help for 2003 Dodge Ram 1500 rough idle issue
Old Aug 21, 2011 | 12:23 PM
IndyRamMan's Avatar
IndyRamMan
Originally Posted by weedahoe
Nope.
Then how are you guys having broken springs without major damage?
Old Aug 21, 2011 | 12:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Some guys get lucky and the valve doesn't drop because the valve breaks and collapses and the retainer stays on top holding the valve in place but cracked open which is why you will have no compression and it won't idle.
Some guys are not so lucky and it does drop the valve and destroy the engine.
Old Aug 21, 2011 | 12:34 PM
IndyRamMan's Avatar
IndyRamMan
53021580AE: have any specs on the spring?
Old Aug 21, 2011 | 12:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
We replace them with 6.1 pushrods and 16 6.1 exhaust springs
http://www.hensonmotorsports.com/mer...tem.php?id=663
http://www.hensonmotorsports.com/mer...tem.php?id=784
Old Aug 21, 2011 | 12:39 PM
IndyRamMan's Avatar
IndyRamMan
Are the factory 5.7 springs the behive style as well?
Have any specs on both the 5.7 and 6.1 sprigns?
Old Aug 21, 2011 | 12:42 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Don't have specs offhand. There are various threads showing both springs side by side. What specs are you wanting btw? Height? Seat pressure? Ect?
Old Aug 21, 2011 | 12:45 PM
bwstewart's Avatar
bwstewart
Just got your messages. Thanks, but unfortunately I just got all of it back together #@!#!! Don't think I even have the equipment to check even if I tore it all back apart.
Sounds like a trip to the dealer garage. I'm guessing that will be a $1000 to $2000. Is it worth investing at 200,000 miles?
There is no other way to check other than getting everything back apart?
Old Aug 21, 2011 | 12:46 PM
IndyRamMan's Avatar
IndyRamMan
yea... height, inst. height, rate, dia
Old Aug 21, 2011 | 12:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well first of all, did you find the problem? If it is the valve springs then use those two links I posted above and order both springs and push rods. That's only 100 in parts. You don't need any special tools other that those to change the springs and like I said, I have a set for sell that i will sell pretty cheap.
Now if you found and have other issues please let us know.
Old Aug 21, 2011 | 12:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sorry. I do not. Perhaps you can call Art or Louis at Hensons at those links above and ask.
