stering wheel stiff!!
Old Aug 23, 2011 | 11:04 PM
rchroca's Avatar
rchroca
Default stering wheel stiff!!
Hello! hi, i'm new here i have a 04 ram 2500 and the recent problem beside the missfire in cylinder #2 that since i bought it (3 years ago) i can not get it out!! last week the stering whell turned very stiff when iddle when rpm are about 500 to 700 when i rive up it turn little soft> what could it be !! from, i can't tellwhen it's moving only when stay still, any ideas please,
Old Aug 23, 2011 | 11:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
the lower the rpm the less the power steering pump is turning which equates to less overall power steering.
maybe you should get a tuner so you can see exactly where your rpms are at and maybe raise the according.
you have been doing all scheduled maintenance right?
Old Aug 23, 2011 | 11:36 PM
rchroca's Avatar
rchroca
yes, i have. it was not doing it before, it just start doing it!!
Old Aug 23, 2011 | 11:37 PM
rchroca's Avatar
rchroca
i did check the receirvore and it's ok, and there is no visible leaks!!
Old Aug 24, 2011 | 10:50 AM
klruff1's Avatar
klruff1
On the misfire cylinder #2, I had the same problem with my 05 Hemi with only 34K miles on it, turned out to be a bad injector. Also replaced the coil, all plugs, and had the dealer do a thorough injection system cleaning, but that did not cure it. About a month after the fix, I had multiple misfires which was caused by a bad gas pedal sensor (potentiometer?), replaced the gas pedal with a new version.
