rear power sliding window
Unfortunately, you must replace the entire back window as it's sold as a whole. That is unless dodge changed something in the past year(doubtful). The only piece you can buy individually is the center glass. That's it. You need to go through the dealer for the unit. I don't think it's too bad, but $400 rings a bell.
You'll need to take the back seat out to acess the motor and brackets. You'll need to take the molding(exterior) off as well so the window can be removed.
You Might be able to go on Ebay and find the track assembly from a salvaged truck, but it's a long shot.
