Lose brakes at full lock
lately (after I switched brake lines) when I turn my wheel the entire way left or right, I lose brake pressure AFTER I get to going. It will stop when I am actually at full lock, but when I get to driving again, the next time I go to press on the brake I have to pump it a few times to get any brake pressure.
I bled the brakes the other day, just a bit of air. I have no idea what is causing this, because I would have figured the rear brakes would still have pressure no matter what.
any ideas?
any ideas?
Not really, but if you did get air in there...
Did you check your vacuum lines off the booster?
Also, did you bleed the back brakes when you did the front? ANytime you break the lines open, you need to bleed all 4 corners.
