3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Check engine light came on code P0748 Pressure Control Solenoid Electrical? I have a 02 Dodge Ram 1500 5.9L. Would it be a bad sensor? Thanks for your help.
I have the same problem which came up after I replaced the pcm. The dealership has replaced the solenoid change the fluid and flashed the pcm but I still have this problem I'm thinking it is the tcm other then that I don't know what else would be the problem. Hope that helps
