Does RP 75w92 need the LSD additive?
Old Sep 17, 2011 | 08:46 PM
stenerson's Avatar
stenerson
Default Does RP 75w92 need the LSD additive?
I'm doing my rear differentials tomorrow. Bought RP 75w140 synthetic. Do I need to add the LSD additive to RP?
Old Sep 17, 2011 | 09:49 PM
LongBed287's Avatar
LongBed287
The Royal Purple website says no. Chrysler additive is mainly zinc and phosphorus. Adding a few extra ounces of additive won't hurt it if your worried.
Old Sep 18, 2011 | 12:08 AM
stenerson's Avatar
stenerson
Thanks LongBed.
Old Sep 18, 2011 | 04:23 AM
abarmby's Avatar
abarmby
No....no additive is necesary with RP.
Don't even add any extra.
Al.
Old Sep 18, 2011 | 08:35 AM
BadHazard's Avatar
BadHazard
I didnt add any extra. Put 2 quarts in and called it good. It was about 1/2 inche below the hole.
Old Sep 18, 2011 | 08:56 AM
HammerZ71's Avatar
HammerZ71
Let the diff tell you if it wants extra.
I use RP in my Grand Cherokee with Vari-Lok lockers front and rear that require additive. With just the RP in them, they will chirp-chirp a little on tight turns and when turning in reverse, so I add about half a bottle in each instead of a full bottle of additive and they shut up.
Go with straight RP first, since it has additive in it. If the diff makes any noise or binds at all when turning, then add a little bit of friction modifier at a time until it stops.
Since I have an Auburn LSD in my Ram, I use conventional lube in the rear which does not have friction modifier in it, so I add a full bottle...
Old Sep 18, 2011 | 09:07 PM
stenerson's Avatar
stenerson
Changed the diff fluid. Running smooth, no chattering.
Also did complete tranny fluid exchange using the return line trick.
I've done just a pan drop the last couple years. Felt good changing
everything this time around. Thanks to the info I've gleamed here.
