I need Help, Misfiring
Old Sep 29, 2011 | 11:08 AM
imyouradmin's Avatar
imyouradmin
Question I need Help, Misfiring
02 Ram 1500 5.9 4x4 Quad cab
My truck has been misfiring lately, I changed the spark plugs wires, distributer cap and rotor, ran fuel injector several times. I never bothered running a code scanner on till it kept happening after we replaced everything listed above.
Problem:
When I start the truck it will sit there for about 2-3 min runs fine, after that the rpms idle down and it seems like its going to shut off, it will keep idling low for about 3 min and then kick in like almsot like it detected the problem and then corrected it, happens everytime the truck starts, obviously if I start to move after that 2-3 min of moving when I hit the gas it misfires and If I push all the way down sometimes it stalls, But like I said if I drive it after that 3 min it will be fine the rest of the travels
Codes:
I hooked up code scanner and am getting P0420 bank 1 and P0138 bank 1 and s 2.
I need help I know basic stuff.
Thanks!
Old Sep 29, 2011 | 08:56 PM
SilverStreak231's Avatar
SilverStreak231
Go to OBD-Codes.com. You can look up any code and what they mean.Looks like either a bad O2 sensor or bad cat.
