Rear transmission shaft bearing replacement
Old Oct 4, 2011 | 07:13 PM
rought's Avatar
rought
Default Rear transmission shaft bearing replacement
A few weeks ago I started feeling a vibration and a vibration type noise at high speeds.. now they are both worse so I checked the rear end. changed the fluid, checked the free play and every thing looks good .. Universal joints all look good too. But the rear transmission output shaft has a ton of play in it and is slowly leaking.
To replace the rear shaft bearing do I have to disassemble the whole transmission or is it possible to replace the bearing without having to completely disassemble the . transmission..?
Ram 1500
2004 quadcab
5-45RFE
Hemi
97,000 miles
