rear diff oil question
Old Oct 5, 2011 | 07:24 PM
mississippi's Avatar
mississippi
Default rear diff oil question
I am wondering if I change out my diff oil would mobil 75-140 be good to use and do I have to add any additive to it if the mobil oil says made for lsd?
Thanks
Old Oct 5, 2011 | 08:52 PM
MikeHTally's Avatar
MikeHTally
Yes and no.
Old Oct 5, 2011 | 08:56 PM
Caseys-dodge's Avatar
Caseys-dodge
If it says made for usage in LSDs I would think that it would contain the necessary friction modifier. After you change the fluid, find a big open parking lot and do several figure 8s. If you have any gear chatter or binding you could just add in a bit of friction modifier.
* but the way everything is marketed now a days you've got to be careful. They say one thing, but it's not really what you think they mean. those tricky ba$tards. That's when you have to start reading the fine print...
Old Oct 5, 2011 | 09:02 PM
HammerZ71's Avatar
HammerZ71
Yep, the Mobil is fine. I have Royal Purple in both diffs on my Jeep with Vari-Lok lockers front and rear which require the additive. I found a bit of a chatter and had to do half a bottle of additive in both diffs for it to be smooth...
Old Oct 5, 2011 | 10:56 PM
mississippi
Thanks guys.
Old Oct 6, 2011 | 08:48 AM
nateroach's Avatar
nateroach
i think a lot of the modern full syn's have the friction modifier in it. I know Royal purple, Mobile 1, and Valvoline Sypower all state that they are designed for LSD's.
nateroach
Old Oct 6, 2011 | 10:07 AM
HammerZ71's Avatar
HammerZ71
Rule of thumb: If it's got the modifier in it, use just the fluid first. If it chirps on turns, add a little modifier to it just until it shuts up. As stated, I have to use 1/2 the recommended amount in my Jeep with a fluid that already has it (or at least RP with it)...
