Pretty good screwup
Old Oct 9, 2011 | 08:58 AM
kln4's Avatar
kln4
Default Pretty good screwup
I was changing oil on my 2500 last weekend and ended up spilling a little over half a quart of oil all over the top of the steering/power steering unit. I wiped it up as best I could and drove the truck to store. The speedometer decided to stop working. Anyone have an idea on how to fix it???????? Did oil drip into the housing or short a wire out some where??????
(My truck is an 02 5.9 diesel w/ cruise control)
Old Oct 9, 2011 | 09:12 AM
BadHazard's Avatar
BadHazard
Are you sure thats all that happened? Considering the power steering pump has fluid in it, I doubt engine oil would cause it to short out. Might want to take a closer look at the engine. Also do you have any codes?
Old Oct 9, 2011 | 09:59 AM
kln4's Avatar
kln4
No codes, but I wish I did.
Old Oct 9, 2011 | 10:02 AM
kln4's Avatar
kln4
I was working under the dash tracing a broken wire to the accessory power outlet while waiting for the oil to drain.
Old Oct 9, 2011 | 10:19 AM
BadHazard's Avatar
BadHazard
maybe while you were tracing that wire, you unplugged, crimped, moved another wire that goes to the spedo.
