Alternator Bearings
Old Oct 11, 2011 | 03:37 PM
toss42's Avatar
toss42
Default Alternator Bearings
How would you go about changing the bearings.I have a /06 Ram1500 5.7L Hemi. Guess there are two(front & rear). With the whining noise I'm not sure which one to change without going to the expense of a garage.Guess the alt would have to come off.
Old Oct 12, 2011 | 09:48 PM
Owensue's Avatar
Owensue
Easiest way is... http://www.rockauto.com/catalog/moreinfo.php?pk=3375009
Just get a new alternator, 15 minute fix.
Old Oct 12, 2011 | 10:13 PM
66three83's Avatar
66three83
Agreed. Why would you bother?
Old Oct 15, 2011 | 08:53 PM
toss42's Avatar
toss42
I agree,but i think that its the idler pulley.the dodge dealership here says that they after changing a few.i just have to wait until next week when their mechanic gets back.will it destroy the belt if it does go?
Old Oct 15, 2011 | 10:43 PM
Owensue's Avatar
Owensue
The idller pulley is an easy DIY, I would get a new belt is it looks cracked or worn. There is a mark on the pulley indicating it has moved too far. Download the 06 service manual from the DIY section and look into it.
Old Oct 16, 2011 | 12:08 AM
Caseys-dodge's Avatar
Caseys-dodge
If its the stationary idler pulley you loosen one bolt, install the new part (about $10) and your done. If its the tensioner pulley, it's the same process. The bolt may be reverse threaded on one of them though, I can't remember.
If the pulley bearings fall apart the pulley will wobble or even fall off and both cases will damage the belt.
