Need help with pass side air bag switch
Old Nov 4, 2011 | 09:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Default Need help with pass side air bag switch
So Theice and i have been going back and forth on some switches and trying to verify a way to determine if a switch is good or bad. Because the switch is more electronic that mechanic and tells the PCM to disable the air bag via resistance, its hard to determine what is good or bad. With that being said, we need someone else with a known working switch to take theirs apart and use a meter to read the two resistors. Its super easy to take apart and here are some pics.
