03 ram 2500 5.7 wont start!!!!!
Old Nov 5, 2011 | 05:24 PM
jonheath84's Avatar
jonheath84
Default 03 ram 2500 5.7 wont start!!!!!
ok here is the deal, while driving down the road my truck died, dash lights, radio,all electronics still working and it wont start back up.it will turn but wont start.it threw 3 codes 2110,2111,2106 all pertaining to throttle actuator control system.i replaced the throttle body and that cleared my codes.i put a new cam pos sensor,and crank pos sensor.i also changed plugs and new battery.i have 50 pounds of fuel pressure a the rail and with a plug tester determined i have spark.still will not start.ANY HELP WILL BE GREATLY APPRECIATED!!!!thanks in advance
Old Nov 12, 2011 | 08:09 PM
Toolman74's Avatar
Toolman74
You changed the throotle body but it sounds like the actuator. Did you check the actuator at all ?
Old Nov 15, 2011 | 10:22 AM
jonheath84's Avatar
jonheath84
yes actually found out the tensioner on the timing chain broke...cant get the crank to turn by hand to achieve tdc.is this normal on a 5.7?
