Where's that u joint thread?
Old Nov 10, 2011 | 07:59 PM
areinike's Avatar
areinike
Default Where's that u joint thread?
I must have read it a few times but now when I need it, I can't find it. I'm replacing both of my joints due to a slight vibration at 55 MPH. I suspect that is the cause of my pinion seal leak. God, I hope.
Old Nov 11, 2011 | 05:45 PM
Gone Fishin's Avatar
Gone Fishin
Federal Mogul precision u-joints they are greasable,
They can be had at NAPA stores if you need them now, but a better place is rock auto---a little less money
Make sure you paint a stripe down the driveline before you remove it, if you reassemble it wrong, you will need to have it rebalanced
Old Nov 11, 2011 | 08:02 PM
areinike's Avatar
areinike
Both u joints were shot. One was seized up pretty good and the other .. well .. found a few needle bearings were in bad shape. Job wasn't hard. I guess if you can rebuild a rear axle, u joints aren't much of a challenge.
Old Nov 11, 2011 | 08:04 PM
areinike's Avatar
areinike
Also replaced the pinion seal. The Timkin I put in there a few thousand miles ago failed. The seal actually split apart. Not something I expect from Timkin. I replaced it was one from NAPA with double seal.
Old Nov 11, 2011 | 08:06 PM
areinike's Avatar
areinike
Timken .. yeah that's it. I'm beat.
